| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40241 09/28/2004 9:54 PM | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Use the lifters that have been running against your camshaft, and don't mix them up from one position to another. Each lifter has established a running fit with its respective camshaft lobe, and if you swap things around, the cam will go flat in a matter of just a few miles. The cam-to-lifter fit gets established in the first few minutes of running of a new assembly, and doesn't need to be disturbed for the entire life of the cam/lifter combination. If you want to clean up the lifters, use clean solvent like mineral sprits, and dismantle, clean, and reassemble the lifters one at a time to avoid mixing up parts. Better method- - - -assemble the engine and adjust the valves, then run a can or two of Bardahl, Casite, or other lightweight solvent-type additive with the oil at a fast idle for a few minutes, then change the oil and filter again. Jerry
Entire Thread
Lifters, pushrods, and oil - Oh my
| Keahi | 09/28/2004 7:39 PM |
Re: Lifters, pushrods, and oil - Oh my
| Hotrod Lincoln | 09/28/2004 9:54 PM |
| Keahi | 09/29/2004 8:03 PM |
| ranger 53 | 10/02/2004 2:32 AM |
| Keahi | 10/02/2004 8:55 AM | |
