Soon I will be installing the new wire harness & fuse box into the 51', and change to 12 volts. I planned to wait to replace the headlight switch untill then (the old wire is rusty & broke, so you can't dim or brighten your dash). Anyway, I have noticed that these switches can run from $20.00 to $60.00, whether they are repro, used, new, with fuse for acc. dome/glove box/tailights. One said as original, for 12 volts, with out acc. for glove box, etc., but using a fuse box, as I will be doing.
I know many of you have probably replaced these switches, is there one design I should install? Thanks!
Bryan
