| | | Forums66 Topics128,276 Posts1,058,440 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | How many screws/bolts hold the valve cover to the head?
2 nuts on the top of the valve cover = 1953 or earlier 216/235.
4 screws/bolts on the edge of the valve cover = 1954-62 235/261
A 230, 250, and 292 would have (I think) more than 4 screws holding the valve cover to the head.
There are other distinguishing characteristics but the above information will get you closer.
The block casting number is at the upper right of the starter. The engine ID (serial number) is pressed into the block just to the rear of where the distributor enters the block. | | |
