I just picked up a 58 GMC that is partially restored and I have some questions
Does anybody make patch panel for 58 from fenders around the headlights?
I have a 60-66 step side short box with the truck
I need to replace the wood and metal strips. I noticed that the mounting will not line up.Later frames must be wider. Do I need to rebuild it as a 60+ or as a 58 box. Can I use the original braces from the 60 box to build a 58 box? or do I need to order everything new?
Thanks
Lindsay
