| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | 41-47 should be the same gas tank......there should be 2 outlets on the bottom of the gas tank........one under the passenger side on the bottom of the tank...........and one under the driver side on the bottom of the tank...........the one under the drivers side is capped and the one on the passenger side is used and a flex tube is screwed into gas tank there.....the hose then goes to side of frame where the solid fuel line goes to carb.....i hope that helps......... | | |
