Ok almost done with the drop axle. I got it from Droppedaxles.com (SID). I got the newer ball joints for the long steering bar that is behind the axle. My ? is about the steering link from the steering box to the arm on the drivers side. The new arm has a solid hole in it, the old arm has a ball on the end that goes into the stock steering link.
Im trying to finish this install tomorrow so all the help will be appreciated.
here is a couple of pics. Do i need to buy a ball and have it pressed in? how does this work?
here is the steering arm im talking about still connected to the old curved arm. You can see the ball inside coming from the curved arm and in the straight arm.
pic1
pic2
pic3
pic4
pic5
again any suggestions will help.
49 1/2 ton project
