woopieee got it fixed.What I had was a fresh rebuilt 2.8 I put in the 41. It had new:waterpump,thermostat,belts,hoses,temp guage,fanclutch 50-50 mix of coolant. radiator was cleaned BUT it ran at 210 degrees weather it was idling or driving. even tried to climb when driving.fan was approx 2in. from radiator. Should have worked.But seemed hot to me.I got to checking and the new fan didnt seem to be pulling much air. So I put on a regular fan with a spacer and that cured it...really p...d me off.took the new fan clutch back and got a refund.Now, I can go crusin toniite..
