0 members (),
171
3
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | I'm trying to install a 302 in my 51 GMC 1-ton and have a problem with the flywheel. I can't use the bellhousing that came with the 302 because it mates to a Clark 5 speed and my truck has the SM420. My 228 bell housing won't accept the thicker 302 pressure plate even when I try the washer trick. I can't use my 228 pressure plate on the the 302 flywheel because the flywheel has a raised lip where the PP bolts go such that my 228 pressure plate would be held to far away from the flywheel to engage.
My question is, can I have the ~1/2" lip machined off of the 302 flywheel and then use my 228 pressure plate? I forgot to mention that I can't just use my 228 flywheel because it is 4 bolt and the 302 is 6 bolt.
Thanks for your help
Izzy | | |
