1 members (TexasA&M48Truck),
67
3
Mod | | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39556 11/13/2003 1:57 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I'll be putting a Rochester Monojet on the manifold of my 261. It has the 1/2 in. thick plastic heat insulator block to separate the carb from the manifold.
The carb rebuild kit came with 3 gaskets which range from thin cardboard to a 1/8" thick composite of some sort.
Are those 3 "gaskets" really heat insulators?
Should I use any of these with the 1/2" heat insulator block? These "gaskets" are not shown in the rebuild kit drawings. Thanks!! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
