Richie Before you get buried(and it happens all the time)you must put the truck back together.The reason for it is,there are 100's of free chassis laying around with mustangII stuff with rear ends, Most guys get all excited about a project and just ripe the body off.You need to put it back on along with a bed ,also the front fenders. Now stand back and look at it.Are the front tires in the wheel wells correctly?(most times that is why they are free) Make sure the rear ones also line up cause if you spend cash to get a driveshaft made and put the body on and the wheel are in the wrong place you need to move the rear and your new driveshaft is JuNk. After that its time to take the nose off and start to install the motor and trans,try to get the dist cap as close to the firewall as possable.Yep the tubular mounts are cut to fit.The raidator will not work,buy a new one when your done ,use the old one for mock up.
