If memory serves me correctly, there is a set screw on your door and window handle. If you're going to replace the post later anyway, you can grind a flat on the post, and the set screw will hold the handle in place. You could even drill a small hole in the post, large enough for the set screw to just enter. That will be even better.
BlueDawg cool
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
