Ok, I have printed and read all I can on this suject and I am now "as confused as a termite in a Yo-Yo".
I am going to install a Chevy small block 350 attached to a 700R4 transmission in my 1941 1 Ton pick up.
I am going to keep the original look as much as possible including the 17" rims with 7.50 X 17 tires 33 1/2" tall.
My stock rear end width is 53" Backing Plate to Backing Plate and 61" Mounting Surface to Mounting Surface.
Can anyone suggest an easy swap. Since I have a 1941 AN rear end it would appear that I can not just change the pumpkin/ring and pinion on my current housing.
Suggestions and are a line on the rear end assembly are deeply appreciated.
Many Thanks,
Dave Murray
[email protected]
