| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | One less-messy way to find a vacuum leak is to use a propane or acetyline torch. Just turn the fuel on, but don't light the torch. Pass the tip around the suspected leak areas, and when the fuel gets sucked into the leak, the engine speed will change. No messy liquids to clean up, and propane doesn't dissolve paint like carb cleaner. Jerry
