| | | Forums66 Topics128,125 Posts1,056,339 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | dj........when you push the plunger it will compress the brake fluid......so even if you had the front end of the mastercylinder closed it would still squirt out some if you have the top vent cap removed.....it sounds like a gumbed up flex brake line to me.......they will get nasty before actual solid lines get gumbed up.......try the bench test.....then if its working good re-install and then disonnect the flex brake line in front from solid line.......you will find out quick if thats the problme........god..arent brakes fun...wink wink | | | |
Entire Thread
Bleeding brakes, but no pressure
| Ol' Red | 03/17/2008 6:20 PM |
Re: Bleeding brakes, but no pressure
| Laurence | 03/17/2008 6:37 PM |
| Ol' Red | 03/17/2008 7:27 PM |
| Laurence | 03/17/2008 7:46 PM |
| Fla54Chevy3100 | 03/17/2008 7:46 PM |
| butch iowa | 03/17/2008 7:58 PM |
| Ol' Red | 03/17/2008 8:16 PM |
| truckernix | 03/17/2008 8:46 PM |
| butch iowa | 03/17/2008 8:57 PM |
| Ol' Red | 03/17/2008 9:18 PM |
| Ol' Red | 03/18/2008 1:16 AM |
| Laurence | 03/18/2008 2:37 AM |
| Ol' Red | 03/18/2008 2:48 AM |
| sixtyfive c-10 | 03/18/2008 4:54 AM | |
