What are the possible 5-speed tranmissions to be found in 1968 C-60? I think 4th and 5th gear are blown in mine and I want to scout junkyards for better ones. also, if you know anything about identify which trans is which or where the serial numbers would be located on the gearbox? I've tried double clutching these gears and they still clash.
