7 members (Maybellene, GMCJammer51, KEVINSKI, Hanks custodian, JW51, 66flea, 1 invisible),
63
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Have a '66 283 stock motor. I don't know if I made a mistake but I have a new radiator with inlet hose diameter larger than my pipe and short hoses that go to the thermostat housing (1 1/2"). The question is: I can connect the hose and pipe to the thermo housing but not the radiator tank because it will not quite stretch over it. What should I do? I hate to eliminate the pipe because then it won't look stock. Is there some reducer that can go on the radiator? Thanks, sovagary
GS
