2 members (BC59, 1 invisible),
117
3
Mod | | | Forums66 Topics128,193 Posts1,057,256 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There is an error in how metric tire sizing works. The second number is the % of the section width (first number) that the hight of the sidewall is. In the example given, a 75%, the sidewalls are 75% of the section width. It isn't 75% sidewall and 25% tread. On lower profile tires, if the section width remains the same, the width increase will not be very great, so a 50 series tire with the same section width will be considerably shorter, but the width will be almost the same, perhaps within a 1/2" of the taller tire's dimensions. If properly plus sized to keep the same diameter, then the width will be increased greatly.
Bill Burmeister | | | |
Entire Thread
Wheel and tire Tech Tip, long awaited, and finally here!!!
| Grigg | 03/04/2008 4:52 AM |
Re: Wheel and tire Tech Tip, long awaited, and finally here!!!
| bucket | 03/04/2008 6:34 AM |
| mikes 63-k10 | 03/04/2008 6:59 AM |
| spanky | 03/04/2008 11:02 AM |
| starkweatherr | 03/04/2008 7:11 PM |
| LONGBOX55 | 03/04/2008 10:35 PM |
| Grigg | 03/05/2008 12:54 AM |
| mikes 63-k10 | 03/05/2008 3:11 AM |
| Grigg | 03/05/2008 4:10 AM |
| 46 Dually | 03/05/2008 4:36 AM |
| Grigg | 03/05/2008 5:12 AM |
| glasman | 03/05/2008 3:43 PM |
| Grigg | 03/05/2008 4:14 PM |
| rustednuts | 03/05/2008 4:56 PM |
| Frank50 | 03/05/2008 8:34 PM |
| Grigg | 03/10/2008 3:32 AM |
| J Lucas | 03/11/2008 4:55 AM |
| OlBlue | 03/11/2008 6:37 PM |
| 46 Dually | 03/05/2008 4:47 AM | |
