The separate line system routes the right wheel line across your tranny support. This is what I did because it meant less tubing and less Ts etc. However be prepared to undo the line if when you ever need to pull the tranny.
http://good-times.webshots.com/photo/2496126880099708909eYOmle
http://good-times.webshots.com/photo/2296483650099708909REbVvy
http://good-times.webshots.com/photo/2347808180099708909POMndH
http://good-times.webshots.com/photo/2143355100099708909ILhKhC
http://good-times.webshots.com/photo/2945019710099708909FleCsL
~Jim
