| | | Forums66 Topics128,259 Posts1,058,299 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 3/4 ton springs will swap, the base 8 leaf 3/4 ton spring is identical to the heavy duty 1/2 ton option. The question is why would you need 3/4 ton springs? You will lose the ride quality, and it will be worsened on a short wheelbase truck.
Bill Burmeister | | |
