| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Definetly use plates. Using washers or nuts is not only illegal, but very unsafe. The wheels need to have a flat surface to mate to. washers and nuts won't provide this, and will cause incorrect torque on the lug nuts. on thing I will mention if you use plated, make sure that the stud length is sufficient. You may need to install longer wheel studs to maintain proper thread engagement, you wan;'t to have at least 1 1/2 times the stud diameter worth of threads to engage the nuts for proper retention of the wheels.
Bill Burmeister | | |
