Donf
Here are the torque reqt
Torque specs are:
main cap bolts 100-110
bellhousing bolts 45-55
flywheel bolts 50-65
rod nuts 35-45
oil pan corner bolts 12-15
oil pan bolts 6-7
clutch pressure plate bolts 25-30
cylinder head bolts 90-95
manifold clamp bolts 15-20
manifold end clamp bolts 25-30
water pump bolts 25-30
spark plugs 20-25
fuel pump bolts 15-20
rocker shaft bolts 25-30
Ganesh
