7 members (55shaker, Woodcmiami, Rusted Nut, Gdads51, CuzzFuzz, Still At It, 1 invisible),
156
2
Mod | | | Forums66 Topics128,138 Posts1,056,441 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Thanks for the advice. I bought a sending unit for a 54 pickup which is not configured to fit the panel tank. I cut the pickup tube above the float mechanism and used standard compression fittings to reconnect and to turn the unit 180 degrees so that it would fit correctly. I then used my original as a template to bend the pick up tube and float to the correct depth. It worked great and I get a good gauge reading. Thanks again Tom and Tim
All the best, Ted
