0 members (),
40
2
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get a cheapy volt/ohm meter & put it across the bat or hot term on the regulator or horn relay. If it reads about 12 volts you have a 12 volt system. Start the truck engine & rev the engine a little above idle. The voltage should go to about 14.0 volts on a 12 v. system or about 7.2 on a 6 volt system. If this happens your system is working & you know which one you have. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
