1 members (1955 1 Series),
93
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I pulled the oil pan off my 4400 shortly after I got it, to see what the inside looked like. I'm kind of glad I did because there was a lot of crud in the bottom of the pan. I had to jiggle it a little to get it out, and I also noticed that the front and rear pan gasket pieces didn't come out with it. Didn't think that was too strange because there was lots of RTV Silicon where the gaskets would be.
Putting the pan back on did not turn out to be so easy. The engine is in the truck, so space and light are limited. I painted the pan and used Hi-Tack to stick on the side gaskets AS WELL AS NEW FRONT AND REAR GASKETS. When I tried to fit the pan back up to the engine it doesn't want to go the last inch or so.
Question 1. Is it possible that someone glued front and rear gaskets to the main caps and they are still up there?
Question 2. Would it help if I removed the piece of sheet metal between the rear of the pan and the fly wheel?
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
