0 members (),
149
2
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36848 06/26/2004 1:09 PM | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | The Zenith 11275 should work extremely well on your 235; however I might suggest trying a different setting before rebuilding. Try setting the idle mixture control screw at 3/4 turn, and the high speed mixture screw at 1 and 1/2 turns (set both after the engine is warm and the choke is off); then adjust your idle speed with the throttle positioner screw. This should lean out the mixture to where the engine will not stall. If not, then time to rebuild the carb.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
