| | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Measure the backing plate on the 216 pump you plan on mounting and duplicate that. If you don't have a 3/4" x 82 deg countersink on hand that will cost you as much as the whole adapter plate.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
