7 members (TexasFarmTruck, RaNfLaS, Gdads51, TexasJim50, Chip O, Thom75, 1 invisible),
89
3
Mod | | | Forums66 Topics128,288 Posts1,058,548 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | AFTER YOU INSTALL THE NEW SPRING, AND HAVE THE WEIGHT OF THE TRUCK FULLY RESTING ON ALL FOUR TIRES, CRAWL UNDER AND DETERMINE IF THE DRAGLINK RUNS UPHILL FROM THE PITMAN ARM TO THE STEERING ARM ON THE LEFT SPINDLE. THE IDEAL, WOULD BE FOR THE DRAG LINK TO RUN SLIGHTLY DOWNHILL. IF IT DOESN'T, YOU MIGHT BE ABLE TO USE A ROSEBUD TIP ON A TOURCH AND HEAT A LONG [6 TO 8IN] SECTION OF THE STEERING ARM AND PRY DOWNWARD SOME UNTIL THE DRAGLINK WAS MORE LEVEL. DON'T FORCE-COOL THE STEERING ARM BY BLOWING COMPRESSED AIR ON IT, LET IT AIR COOL BY IT'S SELF. WATCH FOR ANY POSSIBLE INTERFERENCE WITH THE SHOCK AND ADJUST IF NECESSARY. GOOD LUCK.... | | |
