8 members (Gdads51, rfs56trk, JoeDude, frogfarmer, Jon G, Hotrod Lincoln, gswbbc, Bill Hanlon),
123
2
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36688 04/01/2002 5:36 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Pete, need more description in your posts on what you are working on and pertaining to. It's hard to remember all of a single guys posts here. That said, what ARE you working on? If you have a tork tube, the trans will need to be changed to open line type too and diff rear. If you go to the "archives" and search or the "tech" articles on the main page, lots has been said on these two items. Finding a 55-1 first series will get you an open rear and trans that will just bolt in. Kinda rare to find, specially in New Z I would think. This is assuming you have an AD 48-54. What DO you have and what size? 3/4-tons or one-tons with 4spds are usually all open drive too, even back in the older ones.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
