| | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | To answer some of your specific questions. Yes you wipe the surface down before doing any sanding or painting. No you don't use acetone or laquer thinner. You use wax & grease remover (mineral spirits is a cheaper alternative). You wipe it on wet and wipe it off with a clean rag before it dries. Practice spraying is good. Use something with color so you can see your pattern & overlap. Better than 90% of any paint job is preperation. Be prepared to make mistakes. Don't be upset when (not if) you make some mistakes. No body gets it perfect the first time. Good luck.
