| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | If you have purchased new cables, they probably have only a small cylindrical lug soldered on the wheel end. If so you will need a “U” shaped clevis that slips over this lug and holds a stubby pin that goes through the leaver which pulls the brake shoes. I was never able to find these so made my own. I can probably get you some photos if you need | | |
