Good Morning Everyone. I just got my 1955 lst. Series Chevy truck deleivered. It took over an hour to get the trailer moved around to back it to my stand alone carport. I don't think it is quite as bad as I remembered the 1st. time I saw it. The entire front end has been removed except for the hood. It still has the original front and rear end. The seat has completely dissappeared except for the frame. It is a 5 window and the cab is remarkably good. The door windows and inside panels are gone. The windshield has been shot twice and has a ring around it. The rear and side windows are pretty good. I have a real challenge ahead and look forward to warmer weather to get started. I'm leaning toward a mid to late 70's Nova front and rear end. I also got the 283 engine and powerglide trans. delivered. I will probably totally rebuild the engine, I just don't know whether it would be advantageous to bore and stroke with cams, etc. Any comments or suggestions would be appreciated. I did take some digital pictures and will download to webshots as soon as I figure out how.
Wild Hair
