Try loosening one connecting rod at a time and see if it turns easier after each one. Are you the one assembling the engine?
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
