If the truck has the dual wheel cylinders with the shoes top and bottom, there is a special procedure for bleeding them. That is because the cylinders are vertical and the air doesn't get to the bleeder with the brakes adjusted normally. Read the procedure in the manual.
1951 1 Ton Completed
