2 members (Hush, Forty9),
90
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36170 02/21/2002 5:09 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You must not have removed the pin that holdes the shift selector on the shift shaft. You do not actually remove it but drive it down out of the shafts way, once apart it is removed completly to be put back in from the top on assembly.
See the USA in your vintage Chevrolet! My Blog | | |
