This site will help with gear ratios and speeds:
http://www.onlineconversion.com/bigger_tires.htm
What is your tire overall diameter?
My guess is that you could not pull the 2.41 rear and an OD with the 235 unless a strong tail wind with a good down hill.
2.41 could be about right if you had the SM420 4 speed, then you have a low gear to start with, and the 2.41 is effectively an overdrive once you get to 4th.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
