| | | Forums66 Topics128,154 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35826 02/19/2002 1:21 PM | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | I would like to change the leaf springs on the rearend of my 53 to newer wider type and to eliminate wrap up of older springs ... is there a way to modify the spring carrier to accept the wider leaves or can I remove the carriers from the model from which I am taking the rearend and how does one deal with the fact the frame on the 53 is angled and the frame from which the rearend came is straight?? | | | |
Entire Thread
rear spring swap to wider newer??
| 1tuftruck | 02/19/2002 1:21 PM | |
