Quote
Originally posted by cmayna:
I'm changing my 1/2t from 4:11 to 3:55's.
The 1/2 ton gears won't work in a 3/4 ton.
If you want to stay as stock as possible, the only option is to locate a differential from a 64-72 3/4 ton. Most with automatics had 4.10 gears. There were a few blazers with 3.90s, but not many to be found. You can then swap the center carrier into your differential.
The only other options are
1. Put a later model differential in, they are about 4" wider, so you have to find wheels with the right setback, which is a challenge.
2. Install a second gearbox with overdrive gears.
3. Put on taller tires, but the gain is usually only about 5%.
4. Turn the truck into a 1/2 ton with a differential and IFS that takes you to either 5 or 6 bolt wheels.
Fred
52 3600
69 C-10
