Originally Posted by red58
windshields are expensive enuff to save, seals are cheap enuff to sacrifice, the glass guy is right, you'll likely crack the windshield trying to save the seal, so cut the seal around the outside to remove the flange of it that covers the glass, then the glass can be carefully pushed out from inside
Thanks Bill. I'm not at all concerned about saving the seal, just the glass. So I'll give it a go!
Thanks much.
Anthony
