I have an 88 Gmc and i recently changed motors in it (350 to 305). The oil pressure sensor on the old motor was on the top of the engine in the rear close to the distributor. My new motor (305) the oil pressure sensor is down by the oil filter. Should i move it back up top or will it be fine where it is at? Thank you for your help on my last post too.
sam
