I'm with Cletis, no need to redesign a good design, especially if you want it to look original anyway - any of those clips will result in it being lower, if only because of the 5 bolt wheels/tires you'll wind up with, then there's the fact the rear will still be 6 stud and the disc brakes to set up as well .... and if you're going to hire someone to do it for ya .... $$$$$
