3 members (55shaker, Gdads51, 1 invisible),
67
7
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I would suggest setting the timing the static way. First, adjust the points to spec. Then, turn the motor over to where the small steel ball on the flywheel lines up with the pointer which is in the hole above the starter. The steel ball is tiny, maybe 1/8" in diameter. Now loosen the clamp on the distributor and turn it until the points are just breaking contact. You can test this with a meter. Tighten the clamp and you are good to go. | | | |
Entire Thread
216 Questions
| TexanC3 | 01/03/2008 11:38 PM |
Re: 216 Questions
| LONGBOX55 | 01/04/2008 12:18 AM |
Re: 216 Questions
| Tiny | 01/04/2008 1:11 AM |
Re: 216 Questions
| truckernix | 01/04/2008 1:55 AM |
Re: 216 Questions
| 101053 | 01/04/2008 4:08 AM |
Truck Flywheel differance 1937,38,39
| charlie2 | 11/21/2008 5:57 PM |
Re: Truck Flywheel differance 1937,38,39
| Toyvo | 11/21/2008 10:47 PM |
| Roy Rodgers | 11/22/2008 1:43 AM |
| Tiny | 11/22/2008 2:35 PM |
| truckernix | 11/22/2008 3:36 PM |
| Roy Rodgers | 11/23/2008 8:55 PM |
| Tiny | 11/23/2008 10:50 PM |
| Roy Rodgers | 11/23/2008 11:38 PM |
| Tiny | 11/24/2008 3:11 PM | |
