9 members (Peggy M, JoeDude, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, Stovebolt48, Donf, 1 invisible),
93
3
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | Thanks guys, I am a little concerned about supporting the body. The doors are off and it's sitting on a dolly I made from an old piece of scaffolding. Would it be better to try and take the weight off the floor structure by slightly lifting the cab, say with a cherry picker? I was also thinking of welding a nut to the slotted end of the screws if the impact driver dosen't work. Usually a little heat does wonders too, but I hate to burn them out! Thanks for the advice. Jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
