If it helps, the McMaster Carr catalog gives the max pressures for regular steel brake line as 6,000 psi for 3/16" and 4,500 psi for 1/4". I don't know if this is max working pressure with what factor of safety, or burst pressure, but it may get you in the ball park so to speak.
What are you planning to do?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
