I believe the '41 3/4 ton and '46 3/4 ton are different. The 41's front spindle & king pin is the same as the '41 1/2 ton it's the axle and springs that are different. The '46 spindle is larger. To be sure you need to "mike" your spindle or check the bearing #'s.
