| | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Enclosed drive shaft. 4 speed will not fit. The 37 distance between center line of spring from side to side is 42". Tread width on the 37 tire center line is 58 & 17/32 in. and the dual wheel outer is 73 & 3/8 in. If you want to do this just to install dual wheels if you use a 1930 trans. and rear end that was the first year Chevrolet offered dual wheels and all the parts will fit a 1929.
34 & 35 trucks are the greatest
