1 members (Millenimech),
118
2
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 94 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 94 | ah, a great idea, I should remove the "ignition on/off" toggle switch, in addition to the "push button start", and replace it with a stock ignition switch? I will look for the switch in the regular catalogs.. cheers thanks for the advice. cheers Kevin | | | |
Entire Thread
engine runs, then quit while idling, now will only run with starter engaged
| Kevin Richards | 12/15/2007 4:36 AM |
Re: engine runs, then quit while idling, now will only run with starter engaged
| Flxible | 12/15/2007 4:49 AM |
| atomarc | 12/15/2007 5:13 AM |
| Kevin Richards | 12/15/2007 5:30 AM |
| atomarc | 12/15/2007 6:08 AM |
| Wrenchbender Ret. | 12/15/2007 3:32 PM |
| Kevin Richards | 12/16/2007 10:33 PM |
| Wrenchbender Ret. | 12/17/2007 12:50 AM |
| westratedel | 12/18/2007 7:27 AM |
| Mechainiac_9 | 12/18/2007 11:42 PM |
| Kevin Richards | 12/23/2007 2:35 PM |
| doc41 | 12/23/2007 11:44 PM |
| Kevin Richards | 12/26/2007 3:22 PM |
| rfs56trk | 12/26/2007 6:07 PM |
| Kevin Richards | 12/27/2007 2:41 AM |
| Kevin Richards | 12/30/2007 2:39 AM | |
