1 members (78buckshot),
112
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | You previously stated that the PO had installed a toggle switch and push button starter switch. In order to do this he more than likely hacked up the wires under the dash. You are always going to have problems unless you install the correct ignition switch and straighten out the wiring that goes to it. I have seen a number of these "modifications" and assure you that none of them were done correctly. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
Entire Thread
engine runs, then quit while idling, now will only run with starter engaged
| Kevin Richards | 12/15/2007 4:36 AM |
Re: engine runs, then quit while idling, now will only run with starter engaged
| Flxible | 12/15/2007 4:49 AM |
| atomarc | 12/15/2007 5:13 AM |
| Kevin Richards | 12/15/2007 5:30 AM |
| atomarc | 12/15/2007 6:08 AM |
| Wrenchbender Ret. | 12/15/2007 3:32 PM |
| Kevin Richards | 12/16/2007 10:33 PM |
| Wrenchbender Ret. | 12/17/2007 12:50 AM |
| westratedel | 12/18/2007 7:27 AM |
| Mechainiac_9 | 12/18/2007 11:42 PM |
| Kevin Richards | 12/23/2007 2:35 PM |
| doc41 | 12/23/2007 11:44 PM |
| Kevin Richards | 12/26/2007 3:22 PM |
| rfs56trk | 12/26/2007 6:07 PM |
| Kevin Richards | 12/27/2007 2:41 AM |
| Kevin Richards | 12/30/2007 2:39 AM | |
