| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 9 New Guy | | New Guy Joined: Oct 2007 Posts: 9 | you should be able to put the hole in the tank yourself. Make sure the location will not be in the way any thing in the tank. The hardest thing to see from the outside is the baffles. I had to cut a hole in a stainless tank for a fuel pump. I used a plasma cutter. Good luck! | | |
