9 members (WICruiser, Hotrod Lincoln, 51sub, Steelonsteel, Peggy M, 55shaker, TS3600, GRNHydra, 1 invisible),
124
3
Mod | | | Forums66 Topics128,141 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 94 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 94 | okay, so I was looking at new starters for this truck. In the advertisement online, it states: warning: this starter will be damaged if operated in low voltage environment. Could my non working generator be the culprit? I had been running the engine with a generator that was not doing its job... is this why? I am buying a new starter and I will let you folks know of my progress. cheers Kevin
Entire Thread
engine runs, then quit while idling, now will only run with starter engaged
| Kevin Richards | 12/15/2007 4:36 AM |
Re: engine runs, then quit while idling, now will only run with starter engaged
| Flxible | 12/15/2007 4:49 AM |
| atomarc | 12/15/2007 5:13 AM |
| Kevin Richards | 12/15/2007 5:30 AM |
| atomarc | 12/15/2007 6:08 AM |
| Wrenchbender Ret. | 12/15/2007 3:32 PM |
| Kevin Richards | 12/16/2007 10:33 PM |
| Wrenchbender Ret. | 12/17/2007 12:50 AM |
| westratedel | 12/18/2007 7:27 AM |
| Mechainiac_9 | 12/18/2007 11:42 PM |
| Kevin Richards | 12/23/2007 2:35 PM |
| doc41 | 12/23/2007 11:44 PM |
| Kevin Richards | 12/26/2007 3:22 PM |
| rfs56trk | 12/26/2007 6:07 PM |
| Kevin Richards | 12/27/2007 2:41 AM |
| Kevin Richards | 12/30/2007 2:39 AM | |
