| | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 154 | How about checking if you have power to the ing. points. with the distrubitor cap off and the key switch on check if you have power to the coil and at the contact breaker points. If so start it until it quits. Then check again before you turn the key switch off. As said before You have a loss of power in the system. maybe even the key switch itself. | | | |
Entire Thread
engine runs, then quit while idling, now will only run with starter engaged
| Kevin Richards | 12/15/2007 4:36 AM |
Re: engine runs, then quit while idling, now will only run with starter engaged
| Flxible | 12/15/2007 4:49 AM |
| atomarc | 12/15/2007 5:13 AM |
| Kevin Richards | 12/15/2007 5:30 AM |
| atomarc | 12/15/2007 6:08 AM |
| Wrenchbender Ret. | 12/15/2007 3:32 PM |
| Kevin Richards | 12/16/2007 10:33 PM |
| Wrenchbender Ret. | 12/17/2007 12:50 AM |
| westratedel | 12/18/2007 7:27 AM |
| Mechainiac_9 | 12/18/2007 11:42 PM |
| Kevin Richards | 12/23/2007 2:35 PM |
| doc41 | 12/23/2007 11:44 PM |
| Kevin Richards | 12/26/2007 3:22 PM |
| rfs56trk | 12/26/2007 6:07 PM |
| Kevin Richards | 12/27/2007 2:41 AM |
| Kevin Richards | 12/30/2007 2:39 AM | |
